My festiva has lost spark, I had it sparatically but now it is gone completely.
Here is a list of things that I have done so far.
I checked the main relay, I had the coil and ignition modual checked. Also tested voltage to both. Tested the voltage on the crankshaft position sensor.
I unplugged the vane air flow sensor (mass air flow sensor), and reconnected.
Checked the grounds.
I looked for loose connections and broken wires as well.
I am at a total loss.
Can anyone please help?
