I was putting my gas tank back in the other day and its been so long since i took it out. My question is Im trying to figure out where the 4 little lines go? I know 2 go to the nipples coming out of the tank and one goes down for the line on the tank but theres another one that has a short metal piece, about 2 inches or so coming out of it. I cant seem to find where it goes... Prolly a dumb question and something I over looked but I'd appreciate the help. thanks.
fuel vapor box?
Sorry about the blurry picture, but its the line laying on the filler neck tube. Pretty sure the other three hoses are right. I just cant seem to figure out where that last one goes.
91GL, 93L, 91L, 92L
00 f250- xlt 7.3 6speed 4x4
88 gtx
74 torino- enduro car.
According to the manual, you have a pressurized line, a return line, an evap line (for fuel vapors to go to the charcoal canister) and an overflow line that goes near the filler cap.The left lane? Are you crazy!!! I never drive in the left lane...It's full of freaks driving the wrong way and charging right at you!!!
That may be the line that goes into a rubber grommet in the floor and vents to the space above the axle bracket.
On my '93GL, I had to chisel a larger hole in that area to get a socket on a corroded axle nut that was just spinning around inside that area.
Remove most of your lines there and see if you see that hole in your floor. I'm pretty sure it would be a grommet of some kind, but it's been awhile.
KarlLast edited by Safety Guy; 04-07-2010, 02:10 PM.'93GL "Prettystiva" ticking B3 and 5 speed, backup DD; full swaps in spring!
I believe you are right... there was a square grommet right underneath the filler neck. Here is a pic.
Now heres another question can I just remove that canister in the engine bay and this thing inside the 1/4 panel and just cap the nipples on the tank?91GL, 93L, 91L, 92L
88 gtx
That's what I want to know...My mechanic took it out to make room to fix a brake line and apparently lost it and plugged the hoses, and never told me...I know it catches the fuel vapors from the tank, and a solenoid valve opens under certain conditions to send them in the engine to be burned. I don't know if the ECU takes this into account to calculate the fueling from the injectors and if it messes with driveability though, since my car already had idling issues before that...The left lane? Are you crazy!!! I never drive in the left lane...It's full of freaks driving the wrong way and charging right at you!!!
pics
Only two plugs were used. The third wasn't needed to join the evap to the line leading to the charcoal canister, which I also discarded. We have a "modified" category for emissions checking with a different engine up here. It looks pretty bare without all those hoses. I even threw out that little lip protector for the evap hoses.
The warning message to remove the gas cap slowly does not apply any more since I removed the spring and seal from inside. The black push button is useless. I just like the red color.
I am preparing to chisel the inner weld nuts off to make way for the Millenia gas popper actuator. But that story is for another thread.Last edited by bravekozak; 10-21-2010, 04:50 PM.
