I'm almost ready to swap a BP on my Festiva. Got the head back from the machine shop and assembled most of the engine this weekend. I wanted to clean the fuel injectors and make sure they work okay before putting them on. Checked the resistance and they were all fine. Still wanted to clean them out and make sure they operate well. So I ended seeing a video of someone cleaning his injectors and thought is was a clever idea so decided to something similar. I used two test leads with alligator clips that will connect to a car battery and a fuel injector plug I got at a JY. Spliced a switch on one of the leads to turn on injector on and off (open/close). Then grabbed a cheap dropper (the kind you get for free at the pharmacy) and hot glued a carb cleaner spray tube. The dropper fits perfectly tight on the bp injector end without the o-ring.
To use it, put the dropper on the injector, connect the spray tube to the carb cleaner can, put the injector plug on the injector, and hook up the leads to the battery. Turn the switch on and start spraying. The pressure from the spray will clean the injector nicely and you can see the spray pattern. If you do this, make sure you tape all the wiring ends well to minimize the risk of things exploding
It worked great and I cleaned the injectors in less than 5 minutes.
