Cleaning fuel injectors
  • #16
    That's probably ok. That's how the cleaning fluid would come out if there was no pressure building in the dropper tube. I sealed the top of the dropper where the cleaning fluid goes in to help the dropper get pressurized.
    Oscar
    • #17
      i guess that would make sense. its running now since i changed out the injectors but its giving me this popping noise when i give it gas and it hesitates a bit
      Parker
      • #18
        How's the timing? Any vacuum leaks?
        Oscar
        • #19
          i set the timing right on with all the markings ill check them again but im not sure on the vacuum leaks ill check that too. I also wanted to know when to shift for this 4speed tranny i have because i dont have an rpm gauge yet
          Parker
