Help transmission!!!!
  • Help transmission!!!!
    I have my manual tranny from my ford aspire laying on a table all in one piece now, I just replaced the input shaft bearing and then i tried to putting it into gear by hand and it will not budge???? What do I do?? the shaft spins so do the axles...Im freaking out and dont know what else to do! This is my first time i messed with a tranny.
    You must have one of the shift shafts in a bind. They are very hard to get into gear on the bench.
    -Greg
    Redneck Engineer
    FOTY - '09
      I have rebuilt a few of these transmissions and what I believe is the issue is that you have the internal forks out of position. Unfortunately, you will hae to split the case open again to correct it.
