So my car is all ready to go with it's new engine just have to get it inspected. All that I have to do is set my timing. I know about grounding out the sti connector. My question is this, do I put the white mark on the crank pulley to the pointer sticking out of the timing cover or to the "t" on the set of timing marks? just have heard mixed things when I searched about the white mark, the t with the marks, and the pointer. Thanks all.
Setting timing 92 auto
Tags: None
Anyone??
One real easy way, the woodruff key should be in the 12 o'clock position. On mine, this means the white mark on the notch lines up with the piece that sticks out of the timing belt cover, not the "T" .
Also, the camshaft sprocket has two lines that should be pointing at corresponding marks on the head at the twelve and three o'clock position....Contact me for information about Festiva Madness!
The timing belt is done. I am trying to set ignition timing. But judging from what you said it would be the pointer.Last edited by Sandm849; 04-08-2010, 11:06 PM.
OH! Shoot, uh, I can't remember what the setting is, but the degrees are marked by the "T"!Contact me for information about Festiva Madness!
Haynes says the "T"
Sorry, I misunderstood at first, had lots of dirt in my eyes last night, thats my story, and I am sticking to it!Contact me for information about Festiva Madness!
I picked up a '92 service manual for $1.00 at a used book sale. It must have been for this occasion.
Originally posted by Ford in publication "Festiva 1992 Service Manual"The white ignition timing mark on the crankshaft pulley should align with the white pointer on the timing belt cover.
1. Ground the STI terminal.
2. Check/set the idle speed.
3. Set the timing.
4. Since this the first setting you might want to check the idle speed again, to be sure it hasn't changed, before disconnecting the STI ground.
John Gunn
Coronado, CAJohn Gunn
Coronado, CA
Improving anything
I have the ford service manual...it just says about aligning the white marks. The reason I'm havin doubts is that I don't have a white mark on my timing cover. But I'm going to assume my pointer used to be white from your quote. That was what I was assuming but just wanted to be totally sure. So I'll go with that. Thanks.
Originally posted by Sandm849 View PostI have the ford service manual...it just says about aligning the white marks. The reason I'm havin doubts is that I don't have a white mark on my timing cover. But I'm going to assume my pointer used to be white from your quote. That was what I was assuming but just wanted to be totally sure. So I'll go with that. Thanks.
I got my service manual off the boards here for $20I Wish it had been a dollar, I had to organize and bind it myself!
I just happened to have the haynes on my desk, and it is easier to handleContact me for information about Festiva Madness!
So it's the pointer then? Lack of sleep makes me somehow even more dense.
So I guess the marks are for when/if you manually mark tdc on the crank pulley then?
Originally posted by Sandm849 View PostSo I guess the marks are for when/if you manually mark tdc on the crank pulley then?
On your crankshaft pulley you have two marks. One in yellow which marks TDC for #1 and #3 cylinders. One white one that marks 10* before TDC on those two cylinders, which is the recommended advance for these fuel injected engines.
John Gunn
Coronado, CA
Improving anything
Ok so bottom line is white mark on pulley to pointer. Thanks
You may not want to do this but this is what I did on mine. My covers were messed up so I just turned the disty clockwise till it pinged then backed it off. Although on mine it never pinged so it's turned as far as she'll go (I think). Doesn't have very much top-end but with the auto doesn't need it. Gets 30mpg average with my driving.91 rusty Festiva 260k
