I just re-built my 1.3L FI engine and I went all out: 3 angle valve job, full machine shop work up on the block and head, new pistons, bearings, gaskets/seals, clutch and timing belt.
I have just over $600 invested in this engine but I have a small oil leak coming from the timing belt area and I can't seem to fix it.
I seems to be the front main seal.
I have replaced it 3 times and the last time I use and insertion tool to seat it but the leak is back.
It's fine for about 5 minutes then it starts to drip.
Then I tear down the front end and the front main seal is loose enough to be easily pulled out.
I tried to buy one of those crank shaft repair kits with the sleeve, insertion tool and seal, but none of my local auto parts stores (AutoZone and Advanced Auto, carry them.
A few of you have been invaluable in helping me get this engine re-built and I really appreciate it.
But now my investment will be for nothing if I can't get this to work.
I know many of you thought I was crazy to re-build the 1.3 but it was and still is the best option for where I live.
I thought about pulling the 1.3 and replacing it with a 1.6 so i went shopping and the cheapest engine I could find was over $500 and it had 130K+ miles on it.
