Originally posted by mattdickmeyer
3rd failed ignition module?
Jim DeAngelis
kittens give Morbo gas!!
Jim...Matt...Pu241...We appreciate your help.Last edited by jmye1524; 04-29-2010, 09:45 PM............ With a lever long enough and a place to stand, you could move the world..........
..................Build thread.................http://www.fordfestiva.com/forums/sh...ad.php?t=29547
Originally posted by doylerl View PostYou've got them! I have a disty coming to me tomorrow, and I will get a coil while I am there. If you want them for some kind of study, I would be more than happy to donate them to you for diagnosis! I just don't want to kill another one... this whole new (refurbished) disty just cost me $150! I am not going to shell that out repeatedly!
Have not checked the ground strap... not really sure what you are referring to.
Its a black wire the runs from the right strut tower to the back of the cylinder head. If that is missing, damaged or corroded, it can cause module failure. The ground circuit of the module would have to carry some of the secondary voltage back to the coil.
Also check the ground wires on the transmission for damage or corrosion.Jim DeAngelis
Originally posted by FB71 View Postnearly all modern radios have internal noise suppression circuits that are redundant to the ignition noise suppressor. Digital tuners that can differentiate between a legimate signal and background noise are wonderful things! Oh, and an old Walkman would be MORE suseptable to EMF than the car's radio...
Thanks Jim, your explanation helped me better understand something I though I understood.
So most of the RF interference from the ignition system is a result of the collapse of the electric field across the primary winding with the resulting reverse polarity pulse generating low level RF emissions. So how much, if any, RF is a result of the high voltage arcing across the rotor cap gap?Last edited by Pu241; 04-29-2010, 10:50 PM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
I might as well stick my two cents in here. Have you ever taken the "bad" module out and then put it back in to see if it would then work? The wires that go into the distributor have a sharp bend right at the edge of the distributor housing and I have seen the insulation crack there. It's possible that you are getting a short there and every time you replace a module you "disturb" the short and for a while it works fine. Then the vibration of the car jiggles the wire until it can again cause a short.You gonna race that thing?
Originally posted by Festy46 View PostI might as well stick my two cents in here. Have you ever taken the "bad" module out and then put it back in to see if it would then work? The wires that go into the distributor have a sharp bend right at the edge of the distributor housing and I have seen the insulation crack there. It's possible that you are getting a short there and every time you replace a module you "disturb" the short and for a while it works fine. Then the vibration of the car jiggles the wire until it can again cause a short.Jim DeAngelis
Originally posted by Festy46 View Post. It's possible that you are getting a short there and every time you replace a module you "disturb" the short and for a while it works fine.
Originally posted by zoe60 View PostDid you use silicone grease? They overheat and die if you don't.
Originally posted by skinnypin View Posti had a very similar problema and it turned out to be a fusible link under the hood. i would check that out. could just be a corroded connected or rusted. it will kick in and out and that could cause the car to bog down.
Good ideas everyone... keep them coming. I am getting ready to upload some pictures of the engine bay so maybe someone may see something I might be missing.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Coil: (the red wire attached is for my tach)
Disty: (what is the blue wire that comes off of the disy harness?)
Driver's side firewall:
Looking down at the transmission:
The "ground strap" where it connects to the strut tower:
Where the "ground strap" connects to the engine:
Passenger side firewall:
This is a better picture of the blue wire I was talking about (also, what is the white block with wires going in and out of it):
EDIT:
The coil in the picture is the old one. I just opened the new one and printed on it is
"12V
External Resistor Required"
Do I need a resistor or is it ok to hook this one up as is? The part # is E504P. It is a BWD coil from advance auto.Last edited by doylerl; 04-30-2010, 11:24 AM.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Originally posted by doylerl View PostNever thought about that, but I just installed my new (refurbished) disty in, and still nothing. Keep in mind this thing is supposed to be brought back to "new" condition and tested before sending it to the customer. Now I have NO movement on my tach, where as before it was just slightly moving!You gonna race that thing?
Just jumped it as according to the photo. Still no movement of the tach needle and no start!The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
