There is a Festiva close to me for sale and I am thinking of buying it but the owner says there a no forward gears but it does have reverse. What could the problem be? It's a Five speed by the way.
No forward gears?
Maybe fork problem.
Edit: You beat me to this.
should be 3 forks for the 5spd trans, can't immagine all 3 going bad...Trees aren't kind to me...
Originally posted by FestYboy View Postshould be 3 forks for the 5spd trans, can't immagine all 3 going bad...91 Festiva GL "Scrat"
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
If the car has reverse and you are going to look at it, see if it will go in 5th gear and attempt to move if you "slip" the clutch a little. If it will go into 5th, I would say the shift gate is probably broken and the 1 - 4 gear forks are out of position. That shift gate is kind of a weak spot and is prone to cracking or breaking sometimes.You gonna race that thing?
Originally posted by 1988redfordfestiva View Postno u guys are all wrong the clutch is bad i'm real sure of it if u try all gears and get nothing most likely the clutch is shot
Yes it would be that's why there's 2 sides to a clutch i blew my clutch and only had reverse so i am correct i remember it exactly when my shift rail snapped it was stuck in 3rd i drove off the highway and up my hill in 3rd and when i fixed the shift rail the clutch went bad as soon as i took off. so i dropped it in reverse and backed it into my drivewayFORD BUILT TOUGH SINCE 1987-1993 FORD FESTIVA LX
Originally posted by 1988redfordfestiva View PostYes it would be that's why there's 2 sides to a clutch i blew my clutch and only had reverse so i am correct i remember it exactly when my shift rail snapped it was stuck in 3rd i drove off the highway and up my hill in 3rd and when i fixed the shift rail the clutch went bad as soon as i took off. so i dropped it in reverse and backed it into my driveway
That's about as good as the story about the guy that wanted to know how to stop gas from leaking out of his gas tank after he drilled a hole in it to connect his Nitrous bottle.You gonna race that thing?
