No forward gears?
  • No forward gears?
    There is a Festiva close to me for sale and I am thinking of buying it but the owner says there a no forward gears but it does have reverse. What could the problem be? It's a Five speed by the way.
    '90 LX
    Shift fork is probably gone or near gone. It will need another trans unless you want to get inside of that one and replace a few parts.
    91 Festiva GL "Scrat"
    82 Honda Goldwing GL1100i
    85 BMW 535is "Brunhild"
      Maybe fork problem.
      Edit: You beat me to this.
        should be 3 forks for the 5spd trans, can't immagine all 3 going bad...
          Depends on the abuse factor. I had a 4 speed once that had no gears. When I tore it down the forks were toast. Amazingly enough all the syncs looked good.
            If the car has reverse and you are going to look at it, see if it will go in 5th gear and attempt to move if you "slip" the clutch a little. If it will go into 5th, I would say the shift gate is probably broken and the 1 - 4 gear forks are out of position. That shift gate is kind of a weak spot and is prone to cracking or breaking sometimes.
            You gonna race that thing?
              no u guys are all wrong the clutch is bad i'm real sure of it if u try all gears and get nothing most likely the clutch is shot
                Then reverse wouldn't work either so try again
                  Yes it would be that's why there's 2 sides to a clutch i blew my clutch and only had reverse so i am correct i remember it exactly when my shift rail snapped it was stuck in 3rd i drove off the highway and up my hill in 3rd and when i fixed the shift rail the clutch went bad as soon as i took off. so i dropped it in reverse and backed it into my driveway
                    jesus I hope you're kidding. You can't be THAT stupid...
                    Jim DeAngelis
                    kittens give Morbo gas!!
                      Well, thanks for all the replies, but it sold.
                      '90 LX
                        OMG!! What!?!? Are you serious??....your kidding right??
                          That's about as good as the story about the guy that wanted to know how to stop gas from leaking out of his gas tank after he drilled a hole in it to connect his Nitrous bottle.
                            lol that would have been funny to read lol
                            the heart beat of america stops here______________/\
                            \/\_____________FORD
                            FOREVER
                              I would have told him to arc weld it.
