Is there a step by step way to set timing with pics online somewhere?
First Time Head Gasket Replacement 1988 1.3l
What are the parts #'s for the rad sensors for 1988
I m going to have a new car by the time im done
Just called around no one seems to carry these things.
why does the fan only seem to turn on when I pull the sensor wire?Last edited by yogaslackers; 05-12-2010, 02:36 PM.Slacker Sam
here is the guide for setting the cam timing.
You could have a plugged radiator. Take it to a radiator shop. They can clean the radiator and make sure it isn't plugged. It would be good to eliminate the radiator as a source of the problem.The Festiva Store
Originally posted by yogaslackers View PostOk best I can tell there was some air in the system seems to be working now.
Thanks for all the advice. When I get some extra cash I will be sure to donate
If the car will sit and idle with the radiator cap off and it doesn't puke coolant/steam out the radiator neck, the engine is not overheating regardless of what the gauge says.
You can get the timing pretty close to right if you leave about a 1/4" of slot in the distributor adjustment showing on the top side. If you get some spark knock, back it off a little.
Are you saying you advanced the cam one tooth on the cam gear? Wordn timing belt?Last edited by Mike McKown; 05-12-2010, 04:05 PM.
Yeas advanced the cam sprocket one notch.
head tested no cracks new head gasket
IT IS STILL OVERHEATING wtf,
It was fine for a day ran great 75mph just past the c on the temp gage.
Day 2 running middle of gage
day 3 overheating in 25 miles of interstate driving.
I dont know what to do...
shop of maybe a cliff idk.
thoughts greatly appreciated.Slacker Sam
Originally posted by yogaslackers View PostYeas advanced the cam sprocket one notch.
thoughts greatly appreciated.Last edited by kartracer46; 05-14-2010, 03:39 PM.91 Festiva GL "Scrat"
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
thx for quick post.
runs at 1/3 over c on gage with heat on full blast. if i turn the heat off it over heats... in seconds turn the heat back on and it is super hot almost burns me.
rad plugged on the inside then?Last edited by yogaslackers; 05-14-2010, 04:27 PM.Slacker Sam
You need to find out if it's really overheating or just moving the gauge over to the hot mark.
See if you can run it with the radiator cap off when it indicates hot and see what happens. If it doesn't boil over, it's NOT TOO hot.
If it really is hot, does the coolant look dirty or muddy? Have bubbles in it? Is it losing coolant?
You shouldn't even need a fan as long as you're on the interstate.
Sounds like it may be plugged to me. Take it out and have it flow tested.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
If you have a local radiator shop handy you can take it out and they can flow test it, not certain what they will charge for the service? Or you can take the radiator out, place the cap on it, use an old rag or sock place the end of a garden hose in the top inlet, wrap the rag around the hose so it makes a bit of a seal, then turn the hose on and see how the water comes out of the bottom or outlet of the radiator. If it looks consistant to the flow of the hose and it's not trying to push the rag seal off of the hose then the flow is pretty good and should be OK. If you get very little water and the pressure is bleeding by the rag and trying to push the hose back out the radiator is plugged and will need replaced. This is just a quick test that I use. It's not perfect but it will check flow and flush some debris from the cores while testing.91 Festiva GL "Scrat"
Well if your fan isn't turning on the sensor on the intake is no good usually happens on the stock festy motor and if its over heating take the radiator out run it out with a hose and cold water next your gonna want to go to home cheapo or lowes and get some C_L_R cap both ends of radiator and fill with C_L_R then put the radiator cap on it lay it down for about 10 to 15 mins then shake the radiator the CLR will break up any corrosion from any passages that the coolant has clogged up anyways after you drain the CLR into a clean pale if you have some nasty stuff you'll see it.
Hey its the best thing i ever used and my radiator is nice and clean give it a try...Last edited by 1988redfordfestiva; 05-14-2010, 08:35 PM.FORD BUILT TOUGH SINCE 1987-1993 FORD FESTIVA LX
well if the radiator is clogged, It is better to replace it. Ebay has some generic versions for like $80 shipped or McParts stores have them for $120 or so. A shop will charge more to take it apart and rod it out than it's worth.
CLR is good for rust and iron deposits from running with lack of good antifreeze, but it will not sufficiently remove lime, calcium and flouride deposits. It's a good temporary fix, but it will not solve the long term effects. Once you get the system corrected then be sure to run good antifreeze and add some MACS13 from NAPA to get the inside of the block reconditioned.91 Festiva GL "Scrat"
