Originally posted by Levitan
93 festiva no spark
Originally posted by tim jeffery View Posthi john i have got 4 ign. moduales, and have tried them all, i will check that ground connector you mentioned thanks. little hoe i checked that roll over switch, thanks. when the engine is cranking the power from the coil out is reduced to about 6 volts. thanks tim
My guess is that you are losing the spark somewhere, possibly a cracked dizzy cap or high resistance in the coil lead. Pull off the cap and inspect for cracks, also check the rotor arm, they can crack and the spark will run straight down the dizzy shaft. Check the resistance of your coil lead, giving it a wiggle and bend as you are checking it. From memory 6kohm or less per foot of lead.
