Originally posted by Levitan
93 festiva no spark
Think you mean relay.'93 Blue 5spd 230K(down for clutch and overall maintanence)
If you have 6v engine cranking on the neg of the coil that seems right as the module would give about a 50% dwell to the coil. For the coil to be dropping voltage I would think that the module and coil are ok. It could be a problem on the secondarys of the coil but 3x, you would have to be the unluckiest person around.Originally posted by tim jeffery View Posthi john i have got 4 ign. moduales, and have tried them all, i will check that ground connector you mentioned thanks. little hoe i checked that roll over switch, thanks. when the engine is cranking the power from the coil out is reduced to about 6 volts. thanks tim
My guess is that you are losing the spark somewhere, possibly a cracked dizzy cap or high resistance in the coil lead. Pull off the cap and inspect for cracks, also check the rotor arm, they can crack and the spark will run straight down the dizzy shaft. Check the resistance of your coil lead, giving it a wiggle and bend as you are checking it. From memory 6kohm or less per foot of lead.
