I missed one screw buried in the middle at the bottom of a recess.
It comes apart easily after that. I changed the heater core. The previous owner tried to remove the heater hose by sawing it off. He sawed part way through one of the brass nipples. Then he bent in the side of the tube. I also re/re the impeller after cleaning it with DAX and about fifteen Q-Tips.
Now I just need to buy some foam tape to seal around the plenum.
(re/re = removed and then reinstalled)
