Hi,
I have an 91 festiva which is in need of some brake work. I have taken off the calipers to rebuild them and am stuck on getting the rotors off. I have attached a couple of pictures to better describe where I am at.
The bolts that hold the rotor onto the spindle are on the inside of the rotor and are not accessible. So intuition would tell me that the spindle must come off to get access to the bolts to remove the rotor, but I am unable to get the spindle off. Is it just tough to get off or do I need to do something special?
Thank you for the help.
