I found out my problem with idling is the throttle position sensor but i dont know what to set it at for my bp? does anyone know what i should set it to or how to find out?
TPS settings
please pay attention where you are posting your questions....2nd one moved"FLTG4LIFE" @FINALLEVEL , "PBH"
you posted 2 repair type questions in the general section....did you not notice that they are both moved to repair help?"FLTG4LIFE" @FINALLEVEL , "PBH"
not a problem....that is why I asked for you to look at the sections to make sure you are posting in the right forum"FLTG4LIFE" @FINALLEVEL , "PBH"
sorry...I am not good with that type of repair/diagnosis ...but in your other thread someone mentions you may need different injectors ....they may be right, not enough fuel going through the B3's"FLTG4LIFE" @FINALLEVEL , "PBH"
would you know what i should do though for the tps? when i adjust it, it idles a bit better but when i give it gas it wants to shut off. Does that mean it needs to be cleaned?
