Hey, I've been working on this 1991 5spd, everything was working perfect on the car, then I tried driving it a while, once it warmed up, I tried taking off in it, it died and wouldnt start again, would crank, but wouldnt fire. I left it sit overnight, and then tried starting it in the morning, started just fine. Drove it around, warmed up, died again while taking off, and wouldn't start again.
warms up and dies
we have spark, and fuel i assume, i should probably check to make positive, but i went over to it, sprayed a little bit of starting fluid in the air intake, took a little turns, but she fired. I drove it around for a good half hour, shut if off and started back up multiple times without any problems. soo, it has to be getting its fuel if it kept running, right?-Josh R
I had this same problem on my 93, turned out to be the pickup in the disty(needed to replace dist), once it got a little heat from the engine it quit working. But run it until it stalls and wont restart, then check for spark and fuel.186,000 miles per second is not just a good idea, it's the law
1990 yellow L+ (l8ly)
1990 yellow L+ (sunryz)
1992 aqua L (agua)
1993 blue L (aurora)
Originally posted by JoDan View PostAlso check fuel pressure... not sure on the specs but it might need more fuel pressure to start than it needs to run.
And no, the pressure is regulated by vacuum for emissions primarily. Should be around 40psi KOEO.Jim DeAngelis
kittens give Morbo gas!!
