A/C idler pulley question
  • A/C idler pulley question
    I got my a/c working and have the idler with the long bolt for adjustment, my question is the shoulder bolt goes thru the bracket and the pulley fits on the bolt and the washer and nut goes on the end, is there a spacer somewhere in the mix? It seems very sloppy when tight, thanks.
    69 Shelby GT-350, 351W, 4 spd
    97 Jag xk8 vert
    06 Mini Cooper S GP
    93 Stiva
    04 Volvo S80
    These are the only pieces on the pulley. If you have slop, you likely have a bearing coming apart.
    HTH
    Michael
    Have owned 9 so far
      I will add this, but my camera does poor closeup pics........
      Have owned 9 so far
        ahh, I;m missing the part between the pulley and the bracket, will post on the wtb section, thanks.
        97 Jag xk8 vert
        06 Mini Cooper S GP
        93 Stiva
        04 Volvo S80
