i have searched for a while now going on about 3 weeks, and i have whole 5spd car to swap into an auto, how hard is that? to just pull complete front end out of 5spd with wheels attached, and put it into automatic body. i found the threads were they are just swapping trannys out but im thinking about the complete unit being swapped
swap
whole sub frame
i did im talking about the whole sub frame assembly engine tranny still hooked together. not just tranny. jack body up off of sub assembly that way the link shows just getting the tranny without motor adn putting in car with motor in it. im talking about takin the whole sub assembly with wheels and swapping all at once.Originally posted by 25Horseplay View PostLast edited by bikerdude0269; 07-01-2010, 07:48 PM.
^your asking about: unbolting the strut tops, control arms, sway bar, crossmember, passenger-side mount, steering rack & all the silly little electrical/vacuum/mechanical lines.
All that to swap a trans?
Poverty produces creativity
