Where do you suppose this fell off from?
  • Where do you suppose this fell off from?
    Last Saturday on the highway I thought I was going to die. Above 60 my car should shake violently from the rear end. Felt like the whole car was trying to jump to the left.
    Found this in the street where I parked my car the other day. Usually I park in the driveway, but I had customers so I parked in the street. Could be unrelated.
    I looked around my car and couldn't find anything that looked broken. Front sway bar is just fine (and much larger than that).
    www.dantheoilman.com
    Go ahead and ask me why
    Lower rear shock bolt???
    Ian
      Upper rear shock Attachment.
      1960 willys pickup
      1967 jeep cj5
      1988 festiva
      1989 festiva
      1990 festiva for parts
      1991 s-10
      "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
        X2. But if it's off of your car, you've got serious problems.
        1988 L - 232K miles Batstiva
        1989 L - 247K miles Slick
          X3. But why would it be rusty? It's inside the trunk area. Pull off your trunk plastic and look at the upper mounts. Should be twonuts; the lower one is a flared nut, and the upper is a non-flared nut used for locking the lower one on.
            thats what I was thinking^ If its from the top, it "shouldnt" be exposed to the elements?
            It looks like it would be easy to tell where it came from?
            93L sold. First FESTY!
            93GL Sold Too Soon!
              looks like a rear sway bar link, but i've only replaced the ones on my girlfriend's 323. that's what the bottom end of one looks like though.
              -Zack
                Looks like a front sway bar link to a rear wheel drive GM. Most likely fell/ broke off someone's car/ truck. I would say unrelated to the issues you are having with your car. Unless you're driving the previously mentioned vehicle.
                  Yeah, upper shock bolt would be inside the car.
                  Do we have a rear sway bar?
                  Like I said, it was in the street and I found it on Thursday. So there were about 5 days that it could have fallen off something else.
                  But the violent shake is still there.
                  Which might have been present for a long time. This is the first time I had driven my car "unloaded" so it was a lot lighter. Usually I carry a few ladders and some tools in it.
                    worn struts and unbalanced tires maybe causing the shake rattle and roll.
                      with out a doubt thats the part of the end of the sway bar that goes through the control arm, thats yor whole problem get a new sway bar and bushings
                        the shake is in the rear of the car.....wrong type of bushing for a sway bar. If it was broke like that in the front the strut would move back and forth and pull left and right depending whether he was on the gas or off.
                          Without a doubt, if that is from his car, it is the upper rear strut mount. But I don't think it's from his car. Fairly certain when I did mine, that it would not have been possible to tighten the nut down far enough to have that much threads above the nut. Could be wrong, it's been awhile since I've done the rears.
                            Not to mention if thats from the top of the rear strut, that is from inside the car, and behind the interior panels, how the hell did it get in the driveway??
                            I would highly doubt it came off a festiva since that doesn't look to be from the front sway bar either
                              lol ,thats the rustiest bolt ive ever seen if it fell off your strut it wouldnt have been on the ground unless your strut housing area is as rusted out as that bolt, it would have fell into the hatch area,
                              but that is what it looks like ,rear top srtut bolt that bolt makes me laugh allot thanks for the pic
