Ignition Coil
  • Ignition Coil
    Hey,
    I just tested my ignition coil with a mutilmeter and here are the results.
    Primary: 1.2 Ohms
    secondary: 12,300 Ohms
    Thoughts?
    Bump
    Can anyone shed some light on the test results, want to know if the coil is on the brink?
      Tested hot or cold?
        cold
          well the way i test like all data says check voltage run current of 12 volts to both side of coil one at a time and check the main coil wire for 12 if both see 12 volts then good coil. if not u need to replace and get a new coil. if coil is good u have a wire grounding out with in or out of your electrical system
          FORD BUILT TOUGH SINCE 1987-1993 FORD FESTIVA LX
