so yesterday i bought a new alternator and new battery. i connected everything and turn on the car , i still see the battery sign light up in the dashboard. thought it was the alternator ground cable not connected right so i connected it again, tried turning car on again still showing the light . so there is a ground cable by the starter where those that ground cable goes because i think i have pujt that in the wrong place and that may be the reason that my alternator is not charging the battery. that ground cable by the starter is black and has the whole to be connected smewhere and comes from the harness. where you think it may go? showing me a picture may help please! thank you
help, battery keeps draining may be a ground? alternator not charging battery
Humor me. Start the car, let it idle. Is the light on? Now give it some gas. Does the light go off? Now with the car at idle, turn on lights/radio/blower fan one at a time. Does anything change with the light?
1989 L - 247K miles Slick
okay so i did everything you guys told me but the light stays on. i took the neg cable off the battery and the car turns off... okay so there are two cables under the tranny , that are green do those cables have to do with anything with the alternator not charging the battery? well help me please light stay on. and the ground cableb i was talking about is not the black with yellow stripe i was talking about the black one with the washer where those it go? i put it under the clutch cable by the starter with the one that is black and yellow help thanks. if it doesnt go there then help me please thanks
Maybe you got a bad alternator from the parts store, if youve done everything you think you could do. Take alt back off and have it tested..Originally posted by 1993 festiva View Postso yesterday i bought a new alternator and new battery. i connected everything and turn on the car , i still see the battery sign light up in the dashboard. thought it was the alternator ground cable not connected right so i connected it again, tried turning car on again still showing the light . so there is a ground cable by the starter where those that ground cable goes because i think i have pujt that in the wrong place and that may be the reason that my alternator is not charging the battery. that ground cable by the starter is black and has the whole to be connected smewhere and comes from the harness. where you think it may go? showing me a picture may help please! thank you
