still boggin
  • still boggin
    hey guys i have put my 88 festy back together and i still dont know whats wrong i have set the timing replaced the fuel filter and bought a inline fuel gauge the goes after my mech fuel pump. it tells me that i have between 2 and 5 psi at idle but as soon as i hit the gas the car bogs and dies what is the problem... i think it sat too long and there is a block in the gas tank like another dirty filter or bad gas but didnt think bad gas effects it soo badly. im sorry for rambling but these are my thoughts... HELP PLEASE
    Frankie
    http://www.facebook.com/#!/profile.p...00000110128487
    Could be crud in the carb or a bad accelerator pump. Check the vacuum lines as well.
      so how do i fix that?
      Frankie
        if it helps i managed to drive it to work and then it died as i was leavin work it was perfect when i started no problem whats going on?
        Frankie
          well the gas in the tank is bad but i thought maybe the filter in the gas tank was clogged i blew the system back to the gas tank and tried to start her again still the same thing idles fiine and boggs and dies at 2000- 2500 rpms i miss driving my festy please help
          Frankie
            Does it bog in neutral/park @ 2,000-2,500 rpms?or just under load?
            Go Fast !!,Take Chances !!
              yes i dont dare go anywere like i said this all started after i got to work fine when i went to go home i had to pump the pedal for 8 miles to my house it really sucked i dont know ho to fix it. one of my buddies swears its the accelerator pump. is he right
              Frankie
                well do a visual check.... pull the air cleaner and look straight down the carb then blip the throttle and look for a stream of fuel to squirt from the passenger side of the primary barrel. if you see fuel, then double check your dizzy vaccum connections and test the vac advance diaphram with a vaccum tester.
                  it does squirt fuel into the carb and im not an expert on this stuff at all specially wit vacuum lines i took picture while i was takin the engine apart but some of the pictures didnt show were the lines were going so i might have them screwed up i just dont know which ones
                  Frankie
                    what about the pulse air tube i dont have one anymore could that be why its doing this...
                    Frankie
                      It may squirt but it is not squirting enough fuel at the time that was mines problem.
                      It's the accelerator pump tube it is plugged up take the top of the carb off and pop the tube out and let it sit in a cup of seafom for a hour or two. Then take some carb cleaner and hook the hose to it and spray through it and it will show you how it is spraying. This is what i did with my 88 and it works great now no problems at all. Just the choke is acting weird on it. Try this and it should fix it.
                        thank you so much hy didnt anyone else say that like three months ago
                        Frankie
                          I had an 88 carbed Festy that did about the same thing. Did everything that I could think of including buying a new carb. Finally gave up. Made a deal with my grandson that I would help him change the engine. We pulled the engine and removed the front pulley. Lo & Behold, the front pulley bolt had not been tightened up sufficiently causing the pulley to wear the key as well as the keyway making the timing (valve timing as well as distributor timing) be off by many degrees. We got a new key and "engineered" the keyway, put the same engine back in the Festy, timed it correctly and my grandson has been driving it to work for over a month. So, if your Festy is bogging down with no power and you have run out of options . . . check the front pulley.
                            Hows the car doing? still got the problem?
                              i went to the junk yard near me and picked up a spare carb, pulse air tube and two sensors for like $5 i love the junk yard i get away wit murder.... as goes for the taking the carb apart i havent had time i work 12 hours a day and have a three year old when i get home and at the moment my wife is 2o hours away in Oklahoma
                              Frankie
