Hi Guys - I hope you can help. My 1990 Festy is bein a pain in the you know what. Car stopped running. It will only run if I pour gas in to the throttle body meaning the injectors are not opening and closing. Removing the fuel to the rail and turning the key on produces plenty of fuel. I also bench tested and cleaned all 4 injectors per the post here (that was cool actually and worked well!!!)
I have spark since it runs when I pour gas direct to the throttle body.
I have a new distributor in place from Rock Auto that has all new parts and modules.
Again it runs with gas direct to the throat of the throttle body.
Any suggestions are SO appreciated as I want to get the car running well again. I saw one post talking about the relay on the drivers inner fender by the coolant reservouir. . . what is that? Can I jump it? Ideas appreciated to help. This is driving me nouts.
