Gauge Cluster Removal??
  • Gauge Cluster Removal??
    Can some one please tell me how the gauge cluster comes out the dash? Ive removed the 4 screws but it wont come out enough to unhook. Please help!
    1990 Ford Festiva 196k Automatic (Gone) " It's a small car so you gotta drive it like your ticked off... Small cars need to be driven fast"
    :spam1:is delicious
    You need to unscrew the speedo cable at the trans, thats whats holding it.
    '90 LX
      oh sound simple enough thankx
      :spam1:is delicious
        OH and also does any body know will a 1988 Tracer gauge cluster work in a Festy
        :spam1:is delicious
          Not without modification. Rewiring, and mounting issues.
          -Greg
          Redneck Engineer
          FOTY - '09
            there are also two other groupings of wires that are plugged into the back of the cluster, when you take the speedo cable out be careful notto lose the little brass o-ring that sits on the tranny
            91 red l-
              Brass O-ring?
              Never seen such a thing.... hmmm
              91GL BP/F3A with boost
                Easiest way is just to stick your hand up from the foot well to the back of the cluster, should feel the cable go in with a clip around the cable that attaches to the cluster, push down on the clip so it releases from the cluster and slide it down the cable. Then pull the cluster a little bit out, there should be a black plug on the left and a white plug on the right remove those and youre done.
                93 Ford Festiva WA (project car)
                98 Ford Festiva WF (aspire)(parts car)
                98 "Gloria" Toyota Corolla AE101 (daily driver)
                  I've removed many a Festy speedo cable from a gearbox and never seen any "brass O-ring" either!
                  There is a rubber O-ring that goes on the "bracket" that's held into the gearbox with a hex-head screw that needs a 10mm socket, but I've never seen (nor looked) for anything where the cable screws onto that bracket. You certainly wouldn't need a copper crush ring since it doesn't need to be that tight, and what harm would a little gearbox oil splashing up into the speedo cable do?
                  88L black, dailydriver
                  88LX silver a/c, dailydriver
                  4 88/89 disassembled
                  91L green
                  91GL aqua pwrsteer
                  92GL red a/c reardmg
                  1952 Cessna170B floatplane
                    yea mine didnt have a brass O-ring
                    :spam1:is delicious
                      All our festys didnt have a brass o-ring either.
                      89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
                      My site: 20tessa.sytes.net
