Can some one please tell me how the gauge cluster comes out the dash? Ive removed the 4 screws but it wont come out enough to unhook. Please help!
Gauge Cluster Removal??
Not without modification. Rewiring, and mounting issues.Originally posted by Ephet View PostOH and also does any body know will a 1988 Tracer gauge cluster work in a Festy-Greg
Redneck Engineer
FOTY - '09
Easiest way is just to stick your hand up from the foot well to the back of the cluster, should feel the cable go in with a clip around the cable that attaches to the cluster, push down on the clip so it releases from the cluster and slide it down the cable. Then pull the cluster a little bit out, there should be a black plug on the left and a white plug on the right remove those and youre done.93 Ford Festiva WA (project car)
98 Ford Festiva WF (aspire)(parts car)
98 "Gloria" Toyota Corolla AE101 (daily driver)
I've removed many a Festy speedo cable from a gearbox and never seen any "brass O-ring" either!
There is a rubber O-ring that goes on the "bracket" that's held into the gearbox with a hex-head screw that needs a 10mm socket, but I've never seen (nor looked) for anything where the cable screws onto that bracket. You certainly wouldn't need a copper crush ring since it doesn't need to be that tight, and what harm would a little gearbox oil splashing up into the speedo cable do?88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
All our festys didnt have a brass o-ring either.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
