I have a 88 festy 1.3 ltr and need to replace the brake rotors as they are the original ones. how does one get the bearing hub assy to seperate from the
rotor plate? I have worked on other cars with front disc's but the rotor plate is usually a quite simple, straight forward replacement. Is it pressed on? I know it has locating pins, (4). It is pretty rusted so I tried quite a bit of penatrating oil on it and I used a pry bar and two sides and it still would not break loose. What is the deal with these rotors?
Thanks for whatever help you can give........
jokoza57
jokoza57
