hey guys, i have a really annoying rattle that comes along when my car is idling low. the previous owner said that it was the heat sheild, anybody know how to fix that rattle? i'm saying this assuming it may be common in festys.
rattling heat sheild
Tags: None
May not be the heat shield more common is that the weld to the flange which connects the down pipe to the cat reactor has let loose.
If you get the front up on ramps, it gives you room to wiggle the down pipe to cat reactor connection.
If it's loose it rattles at low engine speed.
Easy fix is to have it tack welded in-situ then unbolt it from the manifold and cat reactor and run a bead all the way around it.'93 Blue 5spd 230K(down for clutch and overall maintanence)
^^^ If that's not the issue then it probably is heat shield. I had the same thing happen on my car and just pulled the shields off.Ian
cool thanks guys, i'll check that when i get it up on ramps
