Replaced TPS and timing seems fine but it still slows waaay down when letting off the gas while doing anything over 40mph. There is not Cat on the car and I don't believe the muffler is clogged in any way. Also did some adjusting to the TPS, I can angle it which helps with the issue but makes the car idle higher, not really sure whats causing the issue.
