Originally posted by Pu241
SPANK is up and running again! ROUGH
My Fleet:
OK, so I went out there today to fire it up and check for fire by pulling the plug wires. Well, it started up and was idleing very low (400rpm?). So I gave it a little gas and it died. Ok, so I will just start it again and let it work itself out. Now I have nothing once again like it burnt the ign. module out again! The tach needle barely moves and it wont start!The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
I am now wondering about the ignition switch. It is the ONLY part of the ignition system I have not replaced. Is there a way to test it? I am assuming there should be 12+ when switched to run and start on the wire going to the positive side of the coil, and a ground on the one going to the negative side of the coil only when the switch is in the off position. Is this a valid way to test it, or is there some other way? Thanks in advance.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
First pull all the plugs out and do a compression test something is oddly wrong then check each spark plug itself to check for spark then you should know either if you have low compression or either bad plugs and wires.Last edited by 1988redfordfestiva; 08-23-2010, 10:51 AM.FORD BUILT TOUGH SINCE 1987-1993 FORD FESTIVA LX
I would be sure you have the plug wires right.I had a chevy nova(Corolla) that did the same thing and it turned out that 2 of the wires were crossed.It ran really funny,but it did run.it would idle ok,get rough as I revved it higher,then smooth out.It was hard to start on occaision,but most of the time it fired right up.Your car sounds like me all over again!!!Go Fast !!,Take Chances !!
Well, just for s&g's I tested the voltage at the coil with the key in the run postion. It only reads at 11.78vdc, where as when I test my battery directly, it tests at 12.4vdc. Should there be that much power lost going to the coil from the switch?The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
UPDATE: I just went out and jumped the + wire from the coil to the + battery post, and unhooked the ignition switch - to the coil and it started! It died shortly after, but that is more than it was doing after driving it around the block the other day.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Originally posted by doylerl View PostWell, just for s&g's I tested the voltage at the coil with the key in the run postion. It only reads at 11.78vdc, where as when I test my battery directly, it tests at 12.4vdc. Should there be that much power lost going to the coil from the switch?The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
