Just got done swapping a 1997 OBD2 Aspire motor into my 1993 Festiva. I swapped everything over from the Festiva just to make sure that there wouldn't be any problems. The only problem that I came about with swapping parts is that the crank pulleys have different timing marks. Almost 90 degrees off!!!
Just last night we got it idling smoothly after timing it. The problem now is that it cuts out under load, or in higher rpms. CEL pops on when it cuts out, and most of the time it will stay running. Tried a different VAF, just in case and it didn't help. Also just double checked the timing. Coil seems to click when it cuts out but has good spark when in idle. Can rev it in neutral too without it cutting out too.
Anybody have any ideas?
Thanks,
Donny
Edit:
#1 Injector seems to be leaking fuel on rail side. I'll try a new O-ring.
Thanks,
Donny
Edit:
