Hi all! Thanx in advance for any help!
I looked in the forums the best I could for answers before posting this, but just wanted finding what i need. Here is whats up.
The other day i was driving my car. Stopped to put air in the front tire, got back in and had NO brakes at all! I checked my master cylinder and my fluid was right up. But NO BRAKES AT ALL!
Limped i to my parents and parked it. Came out after visiting to find fluid on the ground. Found the brake line where it comes thru the firewall on the drivers front wheel to have broken from rust.
So replaced the brake line. And cant seem to bleed the brakes now.
I took the master Cylinder off and bench bled it, but it just doesnt seem to bleed upto full pressure where you can barely push it in. Its a brand new one thats only like 3 months old.
So i got it back on the car, attached the lines, and this is where it gets weird. The Front Passengers side brake will bleed fine, and the rear drivers side wheel will bleed fine. plenty of fluid etc. BUT!!! The Drivers side front wheel and the passengers side rear wheel just do NOTHING.
Does the proportioning valve thing on the firewall, cross over the brake fluid, one front and one rear on opposite sides?
I have done plenty of brake jobs before, but have to say im getting kinda frustrated right now with this one. need my car back running bad, but not sure if its a Master Cylinder problem? or what?
Any and all advice is appreciated!
Thank you!
Ken
Thank you!
Ken
