again... my festiva has issues...
tomo im going to try an intake manifold swap but there are some things that confuse me?
when i grab the pcv valve and rip it out of the valve cover, while the motor is running, the idle dies down. is this normal?
secondly, i had my vent for my blow by going into my air intake and today i found a puddle of oil under neath my air filter, and oil all over my air intake
how could a n/a motor have this much blow by? could something be causing this other then low compression?
i did a compression test and my numbers were around 160 on all 4 cylindres. what are the standard compression numbers on a mazda b6?
thanks for the help in advance.
