The camshaft profile is specific to the mechanical lash adjustment. You'll need to swap in a hyd cam to go along with the HLA rockers.
Personally, with all the problems I have with HLA's, I would prefer to have the mechanical cam and live with adjusting the lash. Throttle response is probably better with the mech cam anyway.
I didn't like the mechanical ones- very ticky. I ran my HLA rocker arms on a carbed cam for a long time with no issues. Don't know if it was right but it ran great. I ran it with the Aspire rollers at first and I know that's wrong but it ran ok. I have an FMS performance cam and HLA's now. It's no B6 but it does alright.
you can swap HLA rockers with mechanical rockers with no issues, just can't use aspire rollers on a non aspire cam. everything else will interchange with out incident. remember, it's the follower that matters, not the tappet end.
That's good to know. I figured since they are a different profile that it would be the same as trying to run mechanical lifters on a hyd grind (and vice-versa) in a V8, where the profiles are specific to the type of adjustment. It may work without causing any mechanical failure, but typically, mechanical cams have less lift & duration and slightly different ramp designs. I think I would still change the cam for optimum performance.
Reason: added comment
