Can I put a 95 Aspire motor into my 88 Festiva without changing the transmission. Will the Aspire motor link to my Trans.?
95 Aspire To 88 Festiva Engine swap/HELP
Yes, you'll need to put all of the carb peripherals onto the aspire engine. Also keep a close eye on swapping the crank pulley. The locating pin is in a different spot on the aspire motor.
Does the Festy carb intake manifold bolt to the EFI Aspire head?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Also does the aspire head have the "spot" for the fuel pump?-Greg
Redneck Engineer
FOTY - '09
they'll fit but you MUST swap over the cam and rockers from the carb head to the EFI head, as the aspire cam doesn't have a pump lobe. OR, you can use the aspire cam and rockers and run an inline fuel pump to the carb.Trees aren't kind to me...
engine swap
I put a 97 aspire engine in a 89 festy carb set up once. The main thing I had to do was put an electic in line fuel pump in. The pad for the fuel pump was there but was not machined and no lobe on the cam as mentioned previos. Put a small relay near the battery for the inline fuel pump so it will come on with the key on position. It also bolted up to the 4 speed that was in the festy. Basically strip down the aspire engine to a long block and go from there. Mount all the carb lines, hoses and all and it should work. good luck with your project.
Oh how I wish it were just a project. Right now, I have a 2002 Mazda Tribute with a blown transmission, A 95 Aspire with a bad transmission, and a 88 Festiva with a blown motor. I own a mobile windshield repair company and can't leave the driveway. I am now planning to take the Festiva trans and put into the Aspire. Will this work, or does anyone have any suggestions?
