I work third shift and usually drive home about 715am, lately the temp has
been around low 40's, high 30's. Whenever I use the heater ( I know that
heat will only come out the floor or defrost vents) , I usually just keep it on
the defrost vents. The car will fog up extremely quick and I have a very hard
time seeing out. I can set it on fresh or recir setting and set the fan speed
on the highest and it just clears out a section on the lower windshield. The air coming out is hot like it should be.
I have a 92 festiva ,5psd. It is blowing out enough air, just don't know if there is a trick to defrosting correctly. Should the a/c
switch be pushed in so the light comes on ? Any help is very appreciated.
