Two Questions
  • Two Questions
    Where is the Fuel Pump Relay located?
    How would I check to see if my VAF is bad?
    Thanks!
    1963 Ford F-100
    1992 Ford Festiva
    2006 Audi A4
    2012 Kawasaki Ninja 250
    Thanks!
    read the ? wrong n posted the wrong thing. sorry
      FP relay is under the left side of your dash.
      There is a bypass for the VAF in the engine wiring near the coil around the left strut tower and firewall. It has two wires and I think one is brown, one black. Put a paper clip or wire in it to check VAF bypass to see if your pump runs.
      Maybe someone else can give better directions.
      Karl
