OK, i have a problem, i have an 89 1.3L fi auto, only has 110000 kelometers and has run fine up till now, the engine has always felt smooth and doesn't burn oil, well, this morning i was on my way to work, and when i came to a stop, the oil light came on.....i instantly shut the car off and check the oil.....full.........so i start it up, and i notice it only comes on at low idel, or if i put it in gear,(when the engine idle drops) I listened to the engine running, and it sounds fine (not clacking like an oil starved engine), and im wondering if the oil pump is on it way out, but why would the oil pump just go, on such a low kelometer engine, and why would the engine not sound like its oil starved, do you think its just the sender? I also drove the car for another hour after this on the highway, and the light never came on till low idel again at a red light (i had to get to work)
any help is apreiciated
