The tubes (on 88-89 models) from the exhaust manifold to air cleaner....and tube from cleaner to catalytic converter. I know it is part of emissions system, heats fuel/air, but the tube from exhuast actually has pressure coming out of it (blows) like there is a pump attached. The tube to the cat has reverse pressure(sucks). What is driving the pressure. Is it working off the exhaust, and "siphoning" it on the cat side?
Pic below of the way mine is now, with all the v. lines and emissions stuff gone. I just took one end of the hose, stuck it on the other for flow thru.
I have seen these tubes cut and bent over to kink it closed on other cars, but does not seem the best way to do it.
