1999 Ford Ranger.4cyl,auto.It use-to not idle well in the cold and when it was wet out.It was only here and there,though.Then it happened more often,but,you would drive it a while and it would start right up and idle fine.Sometimes ,shortly after starting in the morning,I would stop at a stop sign or traffic light and it would want to stall. Prob something stupid.It could be many things,but,I figured I'd ask here first,in case someone on here is familiar with this.
99 Ranger won't idle
IAC sticking would be my guess, while you're checking that, also clean the throtle body and passages. other thing to look for is leaks in the intake tube AFTER your MAF (like in the corrigated areas).Trees aren't kind to me...
+1 ours done the same thing. All we done was cleaned the throttle plate and made sure everything was moving freely.Originally posted by FestYboy View PostIAC sticking would be my guess, while you're checking that, also clean the throtle body and passages. other thing to look for is leaks in the intake tube AFTER your MAF (like in the corrigated areas).89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
+2 I had the same thing happen to me. Except my truck is newer. I would clean the IAC, EGR valve and the passages, Mainly the passages. I had to take a screwdriver and chip out the carbon build up. It shouldent be that hard if you are mechanically inclined. I used carb cleaner on mine.Man should eat when he can for Man does not know when his last meal will be.
Yours is the 8 plug setup?89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
sounds like an easy fix then Tony, git'er dun!Trees aren't kind to me...
The 4 banger with 8 spark plugs?89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
good to hear!Trees aren't kind to me...
