Ok so the good news is I have my panels off ready to be covered in new fabric & door trim is all painted flat black
Bad news is as I drove in the rain to pull rent $ out at bank I noticed my drivers door is leaking at the front dripping down to stock speaker hole(drip seems to be from where window seal meets the side mirror) & it also has a leak by the back dripping down onto the inside of the outside handle backside(seems to have a gap at end of the window seal also). The window seal is in good shape and has tight contact w/ window it just seems to leak at the ends of the seals. I would like to mount door speakers and was just wondering if anyone has had this problem or has suggestions on a way to fix it. Ill try to post pics when rain lets up. Thanks in advance for any advice
