In the middle of adjusting the timing belt....
Backstory:
Previous owner replaced the valve cover gasket because it was slowly leaking. The replacement was terrible, it leaked even worse and dumped oil onto the timing belt among other things. The timing belt flung oil for miles, but finally it slipped a tooth or three. The PO says it runs, but very rough. He showed me it turned over and I heard a few put puts, so it was something to work with.
I bought it (http://www.fordfestiva.com/forums/sh...ad.php?t=33103) and figured I could tackle the timing belt adjustment.
I started it and it ran very rough. I shut it down after a few seconds and looked over the rest of the car. When I tried to show my dad later that night how it runs, it just clicked really hard (not like a solenoid click or something, but a k-JUNK kind of click). I thought it might have been a low battery or something that couldn't push past a compression stroke so I charged up the battery. Same story. Jumped it. Same story.
The last few posts from the link above detail my problem more specifically, but the main points are:
This is an automatic, it's not mtx in gear
I've removed the spark plugs
I can turn the camshaft with a wrench
I can't turn the crankshaft either with a wrench or (as the timing belt how-to asks) by wrenching on the camshaft with the timing belt in place.
The crankshaft does move, but only a quarterish turn.
It feels like there's something in the way of me turning the crankshaft any further and I'm imaginig that's what's holding up the starter as well.
What do I look for?
Thanks in advance.
Backstory:
What do I look for?
