So here is my real question. On the drivers door, is there 2 parts that fold down over the latch or just one? Because right now I can only see one folding down, and its not latching... I drove to work holding the door closed...... hopefully no internal parts are broken.. may take it apart tonight..
door froze- now won't close
-Aspire brake swap COMPLETE!
https://www.wunderground.com/persona...?ID=KOKOWASS38Tags: None
Sounds like the one not folding is frozen in place, try some deicer or just let it thaw a bit.Hotrod Forums Directory * D&D Discbrakes 61-67 Econoline Conversions
I had that problem in my mountaineer all the time. It just needs to thaw out and it will work fine. Your better off not messing with anything, or else your bound to make it worse than it is haha.Originally posted by ejp2fast View PostSo here is my real question. On the drivers door, is there 2 parts that fold down over the latch or just one? Because right now I can only see one folding down, and its not latching... I drove to work holding the door closed...... hopefully no internal parts are broken.. may take it apart tonight..
either put it somewhere warm or try some deicer or something.-------------------------------------------------------------------------------------------
My Musica! Click me!
yeah, i am not messing with it 'cause things like to break when its cold...
i'll thaw it out tonight... should work.
its all good now! just a little frozen moisture....
