Herky Jerky
  • #16
    I agree, its an electrical problem, the CEL came on because you momentarily lost the dist reference pulse, and who knows what else. I think you will find a main harness connector loose somewhere, and since it does it most with a pass then look cloesly on that side.
    97 Ford Aspire 2dr 5 sp
    92 Isuzu Impulse 1.8 5 sp 140HP, handling by Lotus, balls by Isuzu.
    95 Mitsubishi Expo 2.4
    http://img.photobucket.com/albums/v2...64/xsext2a.jpg
    • #17
      try starting the car in neutral, handbrake on. pop the hood and try wiggling the connector on the distributor to see whether the car dies when you do, i had a problem like the one you mentioned that i tracked to that connector having a loose and possible dirty connection..
