so, i was cruising down the highway for about 30 minutes then the heat cuts out. (i didnt know much about the heating system, well i do now) so i just kept driving. i stopped to turn left and alot of smoke came from my hood. i look and antifreeze is everywhere. i take the cap off and there is frozen antifreeze around it so i clean that all off see that it works and put it back on. i cant find a leak anywhere so i figure there was to much pressure so it came out of the upper rad hose engine side.(lots of smoke from there)
I just happened to have some fluid with me so i put that in there and keep going (its not full but im 15minutes to the next town. should be able to make it)
i keep driving and notice that i cant go over 90km even if i floor it. i look at the temp and instead of 1/3 of the way up (normal operating temp for me) its 2/3 the way up. i pull over and the car stalled on me as i slowed down. i pop the hood and i still cant find a leak and the cap is working fine.
i got my hands on some antifreeze fill up the rad. the car was cool by then so i start it up and it starts VERY hard like there is way to much friction. i think i know what happened but the temp never got that high.
because my car has been breaking ALOT the last couple of months i decide to try to drive again(just didnt care) besides i was in -33C windchill for 2:45 and not dressed for it.
was good for a while even went 100km then smoke everywhere including cabin alot. look and finally i saw the leak nice big crack in coolant hose.
today i find out the temp sensor is junk so who knows how hot it really got. i fixed the hose, filled the car up with antifreeze and started it (without cap) to let all the air work its way out. when i turn it on (very hard) antifreeze shoots 1meter into the air and the fan is always running. and my exhaust is very white and could create its own large cloud. i checked the thermostat and its closed but not stuck.
oh and i have a new leak. front main seal.
now the only thing i want to do is take my 16pound sledgehammer and have some fun.
i apologize for writing so much just thought i would give you the whole story.
do you guys think that if i fix all the leaks and just let it run it will be ok?oh and why did the antifreeze shoot out like that?
any help, insight, or ideas would be greatly appreciated.
