OEM horn location in engine bay...
  • OEM horn location in engine bay...
    I'm trying to fix my horn for inspection. I open the hood to look for the horn itself, and find nothing. I looked everywhere within the engine bay. Does anyone have a pic of where the horn is supposed to be? I have an aftermarket steering wheel with the button for it, I just have to see if I can re-wire the darn thing. If not, I'm gonna have to look around in the For Sale section for a used one.
    "There are three things that survive a nuclear war: Roaches, Chuck Norris, and Ford Festivas."
    --Anonymous
    Don't have a pic but mine is on the left/passenger side of engine compartment by the strut tower & alternator. Hope that helps man.
    Send An Invite If Ya Want
    1991 Ford Festiva GL- Auto
      Stock location (at least on the '90-'93 cars) is passenger side behind the front bumper. You have to look up under the bumper for it, its not visible from the engine compartment. Its possible to get it in and out of there with the bumper on, but much easier with it off. I've had to put a new horn on every festiva I've bought lol. You can get a junkyard horn from a lot of different cars, as long as they have only one plug and wire going to them and bolt on with one bolt they are pretty much direct bolt in. The wire is the (+) wire coming in, and it grounds through the bolt. If you get one with a 2 wire plug its not too hard to make that work either, just figure out which side goes to ground and ground it, the other hooks to the (+) wire. I've used horns off of Fords, Nissans, Mitsus, Mazdas, and Chevys on various festivas. As long as they're not huge they usually fit.
      No festiva for me ATM...
        no pic right now but the stock horn locations are the front left and right corners of the front bumper lay down under these corners and look up youll see them Lx's and GL plus's had two horns one on each side and l's and GL's had one horn
        the horns are flat round circles about 3 inches in diameter
        93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
        RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
        RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
        RJ
          LoL guess the PO replaced mine........I wonder if it didn't work and he couldn't find it either and just replaced it. Hmmmmmmmm maybe when it's spring I might try to find it and see if original is still in the bumper :tongue3:
            The original is usually still there, I've seen several at the JY that had aftermarket ones under the hood and the factory one still in the bumper :lol: I think a lot of people just put a new one under the hood lol
              I just checked...they are nonexistant. I'm just going to find one off of the For Sale section here and mount it within the engine compartment.
              --Anonymous
                any horn
                Any horn from any car will do.
                There are a lot of better quality/sound horns than the one on the Festiva.
                I personally recommend two horns with different tones. There is a second wire on the drivers side for the other LX horn.
                  I think I found the perfect horn...
                  --Anonymous
                    http://www.youtube.com/watch?v=6gSsMYjQVnY
                    Agreed!
                    88 Festy L (The White Thunder)
                    91 L came and gone, owned only 2 days
                      That should make you distinctive!
                      You'll be the only member on the forum to have gotten a ticket for blowing their horn. ...
                      Dan
                        I may end up getting this...doesn't require an air tank.
                        --Anonymous
                          http://trainhorns.net/Hot-Rod-Deluxe...c-Horn/675205/
                          IMO, I wouldnt get those, I had a set similar to those in my dodge truck, they turned out sounding like those rediculous horns they start marathons with... I took them out right away
                            Well my options are pretty limited at the moment...it's either this or the dixie horns. And I don't want the dixie horn.
                            --Anonymous
                              collector
                              I have a horn collection of about 30 different horns.
                              My favourite is still the Jubilee bull horn.
                              I almost had a herd of cattle push down a fence when I mooed them.
                              They sure were excited.
                              It's also good for other species as well (if you know what I mean).
                              You will be surprised at what comes out of their mouths.
                              Doesn't work on cats, dogs, sheep or horses very well.
                              These beep beep horns are more for a little Festiva.
