i have a 93 festiva L the dash cluster completely quit working....i have checked every wire, fuses and connection possible... could the cluster be bad???
dash cluster broken!!!
Standard "speedo only" cluster?
Are you talking lighting or the whole shebang? Is your speedo working?
I really can't see ALL the connections coming off at once...speedo clip and two wireset plugs.
Have you taken it out and looked at it?
Originally posted by 93babyblue View Post...need to replace but hard to find parts up here...the lights work but no gauges..'93 Blue 5spd 230K(down for clutch and overall maintanence)
when you get a chance add your location to your profile. As for the speedo....the fuel and temp gauge also do not work? Was this before or after you had it out?"FLTG4LIFE" @FINALLEVEL , "PBH"
You should be able to order a speedo cable from a McParts store; if one doesn't have it, keep looking, someone will be able to get it. Or try RockAuto.com.
Check your fuses if you haven't already, for the broken fuel and temp gauges.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
If the speedo casing is OK, get a core made up at any speed shop. Here are the diagrams for the gauges. They are from a 1990 EVTM, but how much did they change? There is another splice after S219 that feeds the cooling fan relay, or does the key - lights warning buzzer work? If so then the Meter fuse and S219 are good.
