Rear Brakes
  • Rear Brakes
    I have a 93 festiva L and the rear brakes are not working very well. When it is jacked up i can still turn the rear tire while the brakes are being applied. Any ideas on what it could be?
    Also, anybody know how to take the rear drums apart? does it require anything special?
    help would be appriciated.
    could me one or two of many things........from the master cylinder back to the drums........
    Best you spend some time reading posts from others on here about brakes.
      first, does your e-brake work PROPERLY? on BOTH wheels? if not, address the adjuster pivot pin, it's frozen with rust. (20min with some PB and anti-sieze and a hammer and/or vise). if it's a hydrolic issue, replace wheel cylinders and/or soft lines at the swing arm piviot.
        Yes, if you can't release the e-brake it's likely the exposed pivot pin (clevis pin) behind the wheel. The arms rust to the pins if you don't use the e-brake. Regular use should keep them from doing that.
          It take
          88 festiva lx, 2.3 turbo rwd swap in progress
          1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
          R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
          00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
          03' gt, full termi swap 700+ whp build
          sponsered by,
          pam pam's junk, dayton OR.
          Bob's ok tires, salem OR.
          Clausen Truckin', keizer OR.
