1993 5-speed.
On the first test drive after doing a clutch job, I got horrible noises after the first few miles.
A peek underneath seems to show BOTH driveshafts unseated (about 1/4" each) from the gearbox.
During the clutch job, neither driveshaft was pulled out of its front hub.
Here's the process we used:
The chosen method was this:
1. Detach sway bar from lower control arms.
2. Unbolt both calipers (keeping the fluid lines connected) and hang calipers from springs using weedwhacker wire.
3. Detach both kingpins from the struts (two big bolts each side).
4. Pull passenger driveshaft out of gearbox. Leave driver driveshaft installed.
5. Per Haines, detach and lower gearbox a ways.
6. Remove clutch, flywheel, and throwout bearing.
7. Have flywheel machined for $34.
8. Reassemble.
Other than disassembling each side in turn to get enough room to pull out and ram back in its driveshaft, does anybody have any idea what could have caused this? I'm trying to get the car ready to drive to the East Coast. I can't have something like this happening in the middle of Nowhere!
8. Reassemble.
