Aqua's crank seal seems wrong one...
  • #16
    What is that seal removal tool. could you post a pic and where did you get it?
    Great info on lowering the motor to get at the crank stuff. wish i knew it before.
    • #17
      You can buy seal pullers from Harbor Freight, but I'm not sure if "cheap" is the way to go on these. Maybe Sears Craftsman instead? Considering you're working in a delicate area that you don't want to scratch all up, quality might be important.
      In a few minutes I'm going out to prep my car to lower the engine more (alternator removed to allow more lowering) and begin the operation.
      Karl
      • #18
        My new seal's in and I just put oil back in Aqua. Not finished putting the front of the engine back together though. I can't recall what goop to put on the crank pulley bolt!
        Anyone know off hand what kind of sealant or goop to put on the crank pulley bolt? I looked in both my Festiva shop manual and my Chilton's 323 book and couldn't find it. I wiped off the stuff I put on during first reassembly. It was black and rubbery.
        Black RTV maybe?
        Thanks,
        Karl
        • #19
          • #20
            Black RTV maybe?
            Thanks,
            Karl
            Maybe this?
            • #21
              no! NO LUBE. that bolt goes in DRY or with a small dab of BLUE loctite.
              • #22
                Mine was hard enough to get out and it was dry from the factory. i guess. Loosened it by putting the socket and breaker bar on it and resting the bbar against something [forget what] and bumping the starter. i put it back in dry.
                • #23
                  Thanks Arty. I'll probably use that dab of blue threadlocker.
                  Karl
